27 Users Online (25 Members):
Forums >> Revit Building >> Technical Support >> Stair Core Study
Hi to all,
Im currently working on one big project of shopping mall which includes loads of fire staircores. My question is if is possible to build one staircore (one group) with added parameters controlling the width of the staircore wing, height betweren the floors or dimensions of the run and riser?
Im asking because most of the designed stairs have the same height, internal dimensions, construction but the only difference they distinguish from each other is for instance just the width of the stair wing. So as I assume is more easy to set up one group with parameter adjusting needed dimension as to built 6 types od the stair cores.
Thanks a loooot
Luba
You can't add a parameter / label to a stair element. You can embed constraints within the sketch but that's not the same thing. Its not a variable.
I think your best bet is to create a group for each stair width ?
A stair where people can study at. |
Mon, Jan 11, 2016 at 12:56:36 AM
Solar study |
Fri, Mar 13, 2009 at 11:59:45 AM
Change mass colour for massing study |
Mon, Nov 24, 2008 at 4:52:34 AM
solar study + walkthrough |
Wed, May 2, 2012 at 12:47:47 AM
PENTIUM NEW "CORE 2 DUE" (CONROE) v AMD DUAL CORE 4200 |
Tue, Aug 8, 2006 at 9:31:55 PM
