Forums >> Revit Building >> Technical Support >> Using Aligned dimension to manipulate a square to perfect specifications????????
Sat, Sep 21, 2013 at 9:39:24 AM | Using Aligned dimension to manipulate a square to perfect specifications????????
turbostar
Hi everyone,
I seen a technique awhile ago with someone making any random square and using the Dimension -Aligned to manipulate the square their  liking. How do you do that in revit 2012? Whenever i try it, by going into edit mode, my dimensions turn orange and a pop up box opens up, not allowing me to manipulate the geometry.
Mon, Sep 23, 2013 at 8:00:53 AM | Using Aligned dimension to manipulate a square to perfect specifications????????
Is this in a family? an in-place model? or model elements?  WHAT?
How to make an aligned dimension?
Wed, Dec 11, 2013 at 5:19:54 AM
Dimension aligned
Thu, Nov 17, 2011 at 9:49:27 AM
Aligned dimensions on non-orthogonal walls
Sun, Jun 11, 2006 at 8:16:11 PM
Aligned dimensions
Wed, Apr 12, 2006 at 3:22:31 PM
Dimensioning tolerances to use align dimension with grid lines ?
Tue, Feb 9, 2016 at 11:18:30 AM
Page generation time: 1.7066
