Forums >> Community >> Newbies >> Can not swap out one stair family for another
Wed, Sep 18, 2013 at 1:18:26 PM | Can not swap out one stair family for another
VonBraun
Hello
I hope this is something obvious I have overlooked.
I have a file with different stair families. A while ago a use one stair family, imported it into my project by copying and
pasting it into my project file. I then used the stair tool to create the stair I needed using that system family. Now I want
to use a different stair from the same file. I copy it into my project file but REVIT will not recognize it. I can not swap out
my old stair for the new one and I can not re-draw the stair with the stair tool. I just don't have the option to use the stair
system family what so ever. Have tried a couple of different stair families, same result.
I've tried to do this on a couple of different days and it still won't work. In the original file with the collection of stair
types I can swap one family for another no problem.
What do I seem to be missing.
Using REVIT LT 2013
Also upgraded the stair library RVT file and saved it, makes no different to the project RVT file.
Thanks
Wed, Sep 18, 2013 at 1:26:36 PM | Can not swap out one stair family for another
You probably have a corrupted program ....or file.  Try another system with this file to see if its your program.  Try a new file with these stairs to see if its your file.
Wed, Sep 18, 2013 at 1:49:35 PM | Can not swap out one stair family for another
VonBraun
Hub I think your right
I loaded a railing family into my project file in the same manner I loaded my stairs, I am able to use it, draw railings
with it and swap it out for the default revit railings.
I open a new project "basic revit project" and copied in the two stair types I was having trouble with. I can swap them out
for eachother, but can not use them with the stair tool. I can draw stairs with the families pre-loaded into the revit template,
but also cannot swap them out out for the custom stairs I was trying to use. I can swap out the custom stairs for revit template
stairs and back again though.
Also copied a stair from the Autodesk revit file into my project and was able to swap them out.
I think the file with the custom stairs I was using is somehow messed up.
Wed, Sep 18, 2013 at 3:35:13 PM | Can not swap out one stair family for another
VonBraun
Could this be a result of upgrading files from a pervious version? I'm getting similar results with a stair from a previous
office project. It will play ball with the one custom stair family from the library file but not all stairs.
WTF!? Weird
Thu, Sep 19, 2013 at 11:25:16 AM | Can not swap out one stair family for another
VonBraun
Ok new theory
as of 2013 stairs are now component based.
therefore stairs built before 2013 that I downnload off the web are not component based.
Such that they will not work with the new stair tool since they are not designed for it?
Tired this on a full version of Revit on a different comp and got the same results, but at least in full version I can
draw a stair by sketch, where in Revit LT I can not.
Just thought of this, this morning so not sure if I can use the old stair families would work in "draw by sketch" mode as
I only have access to Revit LT at this very moment.
Any thoughts? WWHub?
Attached is the stair file.
Thu, Sep 19, 2013 at 12:18:05 PM | Can not swap out one stair family for another
2013 introduced component stairs but stair by sketch is still available.
In 2014, I just opened my copy of the 2008 stair samples from the on-line library and did several different stair types with no problems.  But I am using Revit - not LT.  LT may be your issue.
Thu, Sep 19, 2013 at 12:24:19 PM | Can not swap out one stair family for another
VonBraun
Was wondering that.
I can convert to a sketch, just can't create a stair in Revit LT that way. I actually just crashed revit with trying to edit a stair sketch. The stair
I was trying to use actually copied in as a sketch, I'm thinking this is why doesn't work with the stair tool.
One family parameter has formula one has none
Wed, Jun 25, 2014 at 1:05:54 PM
2013 stair path symbol for component stairs displays differently
Thu, Feb 6, 2014 at 3:03:50 PM
Add Title Block to multiple sheets quickly?
Tue, Mar 29, 2011 at 10:36:15 AM
Performance lag with Type Selector
Fri, Feb 4, 2011 at 8:48:11 AM
Title block, not the usual question
Wed, May 9, 2012 at 8:16:08 AM
Page generation time: 0.6943
