Forums >> Revit Building >> Technical Support >> Conceptual Massing Loading Problem
Wed, Sep 18, 2013 at 2:46:27 AM | Conceptual Massing Loading Problem
TheLamb
I'm using Revir 2013, and I have a problem when reloading a conceptual mass to the project file:
  • I create say, a cube in conceptual massing, load it into the the project and insert at the desired point.
  • Then, say, I create another cube next to the original cube in the conceptual mass and reload.
  • Once reloaded the position of the original box has moved.  It seems that Revit is recalculating the the insertion point on a a centre to centre rather than the original origin point.
Any one got any ideas, this is driving me nuts?
Thu, Sep 19, 2013 at 12:13:40 PM | Conceptual Massing Loading Problem
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
That is odd behaviour. The original two reference planes in the Mass family template 'define the origin' of the family. That is the base point 0,0,0 of the family.
I tested your process by adding in 2, 3, 4 more mass extrusions to the original mass family, reloaded it, overwrite,  and nothing moves. Just the new masses show up.
Something you are doing or missing. Upload your mass family. . . . .
2010 Conceptual Massing and .sat files
Fri, May 27, 2011 at 12:46:18 PM
conceptual massing...undulating roof shape
Thu, Jun 24, 2010 at 3:01:55 PM
Conceptual Massing Problems
Sun, Jun 28, 2015 at 10:22:44 AM
how to add an edge in an conceptual massing
Sun, Jul 24, 2011 at 2:36:43 AM
cannot control profile direction in conceptual massing mode
Thu, Jul 1, 2010 at 5:13:47 AM
Page generation time: 0.7125
