Forums >> Revit Building >> Technical Support >> Show Hidden Lines Creating Double Lines
Mon, Sep 16, 2013 at 3:52:08 PM | Show Hidden Lines Creating Double Lines
palladio1234
5 Stars: 3 Votes
Anyone have the same problem as me?  When I show hidden lines anytime I always get two double lines that are not right on top of each other perfectly and it ends up looking like a solid line.  My guess is that revit is showing the other edge of the geometry and the other edge is not the same length as the edge closest to me therefore it creates overlapped dashed lines that look solid (no space between each dash).  Can revit be told to only show the edge of geomatry that is closest to the drawer? It seems like no matter what it shows all edges of the geometry being told to show through.
Mon, Sep 23, 2013 at 11:55:16 AM | Show Hidden Lines Creating Double Lines
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Haven't seen this before (and don't use show hidden line much) and would be surprised there is a built in work around for something that's not supposed to happen. If the lines are lined up they shouldn't offset ? Perhaps this is common. Not sure.
Elevation/Creating Hidden lines
Fri, Mar 12, 2010 at 12:43:17 PM
Show Hidden Lines Tool and Detail Elements
Fri, Nov 22, 2013 at 8:48:50 AM
Footings, getting double hidden lines and intersections suck!
Fri, Aug 31, 2012 at 10:13:08 AM
Show Hidden Lines - Structural Foundations
Thu, Jan 13, 2011 at 10:37:01 AM
Hidden Lines disappeared from all my Elevations
Fri, Mar 1, 2013 at 12:37:04 PM
Page generation time: 2.5004
