Forums >> Revit Building >> Technical Support >> Cut Pattern Line Weight
Mon, Sep 16, 2013 at 2:28:40 PM | Cut Pattern Line Weight
palladio1234
5 Stars: 3 Votes
I thought one could control cut pattern line weights with "model line weight 1" under manage>additional settings>line weights.  Is this not the case anymore?
*** nevermind revit wont show you the changes unless you hit "OK" and not just "apply" ***
Edited on: Mon, Sep 16, 2013 at 2:31:21 PM
Tue, Sep 17, 2013 at 12:41:27 PM | Cut Pattern Line Weight
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
If I understand the question correctly you need to adjust the lineweight in the Object Styles dialog box.
Lineweight > Cut and Projected for each element Category and Subcategory.
Tue, Sep 17, 2013 at 2:34:53 PM | Cut Pattern Line Weight
palladio1234
5 Stars: 3 Votes
dgcad, that is correct for cut or projection lines, but if you would like to adjust the actual cut fill pattern linework you need to change line weight 1 in your lineweights dialog box.  This is under the manage>additional settings>lineweights.
Impossible to change ceiling pattern line weight
Tue, Jan 22, 2013 at 11:03:23 AM
SURFACE PATTERN LINE WEIGHT
Fri, Mar 28, 2014 at 2:30:00 PM
Floor Pattern Line Weight
Wed, Jan 17, 2007 at 2:47:21 PM
Surface Pattern Line weight of walls
Wed, Nov 4, 2009 at 4:22:31 PM
Split face pattern line weight (2009)
Tue, Aug 19, 2008 at 2:57:25 PM
Page generation time: 3.2689
