18 Users Online (17 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Lineweight in perspecives
Mon, Sep 16, 2013 at 10:44:09 AM | Lineweight in perspecives
SteveB
3.5 Stars: 5 Votes
is there a way to make the lineweight in perspective line drawings thicker?... or to control lineweights in general.
Mon, Sep 16, 2013 at 11:12:53 AM | Lineweight in perspecives
The liework tool is available in all views.  In addition, you can set different lineweights for every category in view VG.
Tue, Sep 17, 2013 at 4:50:45 AM | Lineweight in perspecives
mathill
There are settings for global lineweights for model, perspective and annotation under additional settings.
Tue, Sep 17, 2013 at 5:53:36 AM | Lineweight in perspecives
SteveB
3.5 Stars: 5 Votes
In the same pursuit of exporting line drawings, is there a way to export line drawings where the "white" areas are transparent, for use in photoshop? I tried exporting as a .png but the white areas were opaque in photoshop. Anyone know how that would be done?
Tue, Sep 17, 2013 at 8:14:31 AM | Lineweight in perspecives
Not from Revit.  You will have to change that in another program like photoshop.
Tue, Sep 17, 2013 at 8:15:58 AM | Lineweight in perspecives
SteveB
3.5 Stars: 5 Votes
thanks.  You make this site a great resource.
Wed, Sep 18, 2013 at 12:27:42 AM | Lineweight in perspecives
oelgustav
which version of revit are you using...well for these recent versions (am not sure about the older ones) that's easy..be sure to be on that view then go to the view tab,under the render gallery you'll see the arrow when you click it you access the gd or graphic display options,under silhouettes you can whatever the linetype you prefer that is if wide lines for thick lines,medium and so...otherwise you can also try to override the properties too,just right click and choose override then go to projection lines...hope that helps too
Lineweight on Surface Patterns?
Mon, Jun 15, 2009 at 11:54:52 AM
Lineweight Problem
Tue, Jan 19, 2016 at 2:26:31 PM
Electrical Fixtures Lineweight
Tue, Jul 21, 2015 at 12:39:00 PM
Linked Cad - Global Lineweight
Wed, Sep 2, 2015 at 4:54:03 PM
Coordinating Lineweight of Revit to Cad
Fri, Dec 7, 2007 at 11:17:24 AM
Page generation time: 0.9107
