Forums >> Revit Building >> Technical Support >> Default text leader location - top right
Thu, Sep 12, 2013 at 8:20:38 AM | Default text leader location - top right
ashevilleARCH
Is there anyway to set text to default to a top right leader instead of bottom right?  I can't think of a time I would ever want a bottom justified leader (my opinion...not opening that drafting standard for discussion) and it's driving me crazy to have to change this every time I open a new session of Revit.
Thanks in advance.
Revit 2013
Thu, Sep 12, 2013 at 8:44:06 AM | Default text leader location - top right
Most operations in Revit default to the last used settings. Open your tempate and do a note with the proper setting.  Delete the note then save the template.
  I'm not saying this will work but you can try it and let us know.
Thu, Sep 12, 2013 at 8:53:40 AM | Default text leader location - top right
ashevilleARCH
I wish it were that easy!  In the same drawing right now I can create text, set to top right.  Tomorrow when I start Revit again and open the same drawing it will be back to bottom right.  I'm sure the same would apply to the template.
Leader Question
Thu, Jun 16, 2016 at 12:24:28 PM
leader attachment to text in drawing with split view
Tue, Jun 9, 2009 at 11:34:49 AM
Multiple Leader Text
Sun, Nov 18, 2007 at 12:33:40 PM
ARC LEADER NO TEXT
Thu, May 2, 2013 at 10:36:04 AM
Arrowhead start position with text box
Mon, Aug 3, 2009 at 9:19:59 PM
Page generation time: 0.3913
