22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> surface pattern visibility
I have a concrete foundation wall and I able to see 3 out of the 4 surface patterns. of course some my section are in the view that the fourth surface which doesnt show the pattern.
"of course some my section are in the view that the fourth surface which doesnt show the pattern."
This makes no sense. Are all of your foundation walls at the same height so your view range is cutting through them? Are they all the same type of wall? Are they all on the same phase?
Yes, all of your foundation walls at the same height.the cut pattern is not in question. when I actually cut through the foundation wall the cut pattern shows up. its the surface pattern on one side of the wall that is not showing. all the VG is set correctly. the reason this causes an issue is some of the foundation walls are slightly above grade.
Post an image of your problem. Do you have a surface pattern applied in the material?
the surface material is applied to the material. I am attaching two pdf's
Have any graphics been overridden in that view? Is there anything infront of them that would be hiding the pattern?
Edited on: Fri, Sep 13, 2013 at 9:11:27 AM
Is the wall placed correctly - outside finish out? (And the wall built that way)?
surface pattern visibility issues |
Thu, Jan 5, 2006 at 3:13:47 PM
surface pattern visibility |
Mon, Dec 8, 2008 at 4:14:14 PM
Surface pattern |
Mon, Sep 10, 2007 at 11:18:01 AM
Surface pattern move/align/adjust problems [ 1 2 ] |
Thu, Sep 17, 2020 at 10:29:33 AM
19
SURFACE PATTERN LINE WEIGHT |
Fri, Mar 28, 2014 at 2:30:00 PM
