16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> Material take-off no totals
2 Posts No Rating |
Hi,
Sorry if this is a repost but I've created a material take-off for floors. And unless I itemize every instance I get no value under area and volume. When I go to the format tab "calculate" totals is greyed out. I've attached a screenshot. All I want to get is area and volume listed with having it show an area for each floor.
2 Posts No Rating |
*with out it showing each floor
24 Posts No Rating |
I think you should try grand totals under Sorting/Formatting. You can use filters to omit the rest of the floors and show the one you need. You should add Floor parameter to schedule. Hope this helps.
In Solidarity |
Schedule Totals |
Wed, Jan 6, 2010 at 2:00:46 PM
totals in area schedules |
Thu, Nov 6, 2014 at 1:28:50 PM
which parameters can have totals in schedules? |
Fri, Nov 8, 2013 at 10:37:49 AM
Material Take Off Totals |
Wed, Sep 25, 2013 at 11:47:53 PM
Calculating with totals |
Tue, Mar 4, 2008 at 2:48:12 PM
