9 Users Online (7 Members):
Forums >> Community >> Newbies >> Giving the roof the texture of a roof tile
7 Posts No Rating |
Hi. I am a beginner and I am doing a residential project. I have a sloped roof and I want to show that the roof has roof tiles but only using texture and not actually making roof tiles. Can anyone help me please. Thank you
24 Posts No Rating |
Hi,
You should try applying material from the material library. When you create the roof, just go to roof properties and edit material. You should find some default materials for roofing in Autodesk Library. You can even edit the image and use your own or material swatches from internet. Just make sure the scale is appropriate. If you are only looking for hatch, then you should still be able to do that from properties,, except you should use the graphics tab in Material browser and change surface pattern.. and use Model patterns. I know this can be confusing,, but check out some tuts on materials and hatches in REVIT.
In Solidarity |
7 Posts No Rating |
Great. thanks a lot.
And if I download from the internet, how do I import it in my project?
Thanks
Always read the similar threads listed below your thread
\/...start with this one:
http://www.revitcity.com/forums.php?action=viewthread&thread_id=9116
Roof texture problem. |
Tue, Jan 7, 2014 at 10:05:07 AM
Barrel tile roof by extrusion |
Fri, Jan 14, 2011 at 1:10:17 PM
Roof Tile Material..... Monier Life Tile |
Mon, Oct 31, 2011 at 2:15:22 AM
Roof Tile |
Sat, May 15, 2010 at 2:50:33 AM
Three-Dimensional Tile Roof |
Sat, May 30, 2015 at 10:43:29 PM
