Forums >> Revit Building >> Technical Support >> Tag Rooms in ceiling plan
Sat, Sep 7, 2013 at 9:28:23 AM | Tag Rooms in ceiling plan
SteveB
3.5 Stars: 5 Votes
Is there a way to control the level or height at which the room tag function reads the room?  When you try to tag rooms of a ceiling plan, the rooms names that come up are from levels below, not useful.
Mon, Sep 9, 2013 at 7:38:28 AM | Tag Rooms in ceiling plan
Steve - not sure what you mean.  The rooms being tagged should be on the level the ceiling is in so - yes - the room from below.
Mon, Sep 9, 2013 at 9:07:42 AM | Tag Rooms in ceiling plan
SteveB
3.5 Stars: 5 Votes
I have created all floors of a house.  I have labeled the rooms names and numbers.  Now I create ceiling plans for electrical and lighting design.  I'd like to label the room names on the electrical plans.  when I do so, they names that come up on the electrical plans read levels below them...sometimes.   See video... http://screencast.com/t/FCetvLfu1U
Mon, Sep 9, 2013 at 9:13:30 AM | Tag Rooms in ceiling plan
The only rooms that will read are rooms that are cut by the view cut plane.  Check out the height of the offending rooms - that shows up in the room properties.  ALSO - pay attention to underlays.
Mon, Sep 9, 2013 at 9:43:05 AM | Tag Rooms in ceiling plan
SteveB
3.5 Stars: 5 Votes
I figured it out.  If i selected the basement rooms that were eroneously reporting on levels above, the room properties had "upper limits" and "upper limit offsets" above the ceiling heights of those rooms.  I don't know how they were created that way, but resetting fixed all the room tag problems. Thanks.
floor height tag in reflected ceiling plan (2015)
Fri, Mar 12, 2021 at 3:49:52 PM
14
Room Name w/ manually entered Ceiling Height
Mon, Jan 19, 2009 at 3:50:30 PM
Ceiling tags: how can i make them visible in floor plan views
Thu, Dec 6, 2012 at 3:59:35 PM
ceiling tag for mass created clg.
Mon, Jun 2, 2008 at 12:38:04 PM
Tag Suite and Maintain Rooms
Mon, Oct 28, 2013 at 8:58:38 AM
Page generation time: 0.7375
