Forums >> Revit Building >> Technical Support >> Annotating a linked cad plan
Fri, Sep 6, 2013 at 1:44:22 PM | Annotating a linked cad plan
Marissa
Using Revit 2013.  We have a cad floor plan that we've linked into our Revit model. We want to annotate it using Revit's "User Keynote tags", but it's not allowing me to keynote it.  We don't want to redraw the plan in Revit as this is an entire building we're demolishing.  Any ideas on how to keynote it?  Thanks!
Mon, Sep 9, 2013 at 2:51:16 AM | Annotating a linked cad plan
ronmalit
5 Stars: 3 Votes
hi.
open new family>generic detail item>import DWG>load detail item to revit>you can now use keynote and select the DWG. (if cannt tag then try to explode DWG in the detail item editor)
** dont be mad, i dont have much... i am homeless
Mon, Sep 9, 2013 at 7:41:44 AM | Annotating a linked cad plan
You can create a detail family that can be placed then keynoted.  We put an invisible line (circle) in the detail so that it will host the keynote.
revit freezing and not responding when cad file linked
Fri, Feb 6, 2015 at 11:24:56 AM
Linked CAD and Scaling
Tue, Jun 4, 2013 at 12:56:58 PM
Linked Cad File does not show Cad Xref's
Fri, Sep 10, 2010 at 10:13:50 AM
Constraining to linked CAD file
Thu, Apr 4, 2013 at 3:09:14 AM
Problem exporting view with linked CAD file
Wed, Mar 18, 2009 at 3:46:34 PM
Page generation time: 0.4954
