Forums >> Revit Building >> Technical Support >> pipe insulation and VG
Fri, Sep 6, 2013 at 1:31:50 PM | pipe insulation and VG
vinnygolfer
4.5 Stars: 4 Votes
using revit 2014. is there a way using VG and/or filters, to hide the insulation on a system type. i'm trying to show the HHWS&R piping but not the other piping. i can use filters to hide all the other pipe systems, however the insulation for those systems still remains, and i can't grab it to hide it in the view.
Try to learn at least one new thing every day
Fri, Sep 6, 2013 at 2:08:39 PM | pipe insulation and VG
Johnzo142
This may be obvious but did you make sure that pipe insulations is checked in your filter categories?
Edited on: Fri, Sep 6, 2013 at 2:09:28 PM
Spot elevation Tag and Insulation
Wed, Jun 11, 2014 at 10:00:27 AM
Revit 2013- Pipe Insulation
Sun, Nov 25, 2012 at 3:03:00 PM
Plumbing insulation
Thu, Feb 20, 2014 at 8:19:48 AM
Hide insulation in MEP 2012
Wed, Sep 5, 2012 at 3:39:14 AM
centerlines and insulation
Wed, May 6, 2015 at 2:49:05 PM
Page generation time: 0.1039
