12 Users Online (10 Members):
Forums >> Revit Structure >> Technical Support >> New to revit, overlap visibility problem
2 Posts No Rating |
Hi, i'm new to revit and would like to know how to set layered visibility on objects or a similar feature.I'm tryn to build a roof where i have the framing into the roof and need it to display realistically in a section.The roof cut shading seems to have priority over the beam cut shading and i need those beams to stand out from the roof in shaded section view
Here's a photo
Any help pls?Thnx
You know what you mean but you have not expressed it. My best guess - change the material color.
2 Posts No Rating |
My english is not much better than my revit skills .I'm tryn to just have the thing visible, autocad style, with layers.The colors are different but i don't know where visibility rules are, who has priority.I will bump into this a lot so ... the colors are different .. i attached a new pic
Typically, there are no priorities. A solid in front of another solid will be solid and the element behind will not show through. There are some over-rides that can be applied by category, instance, phase or filter but the default is as I initially stated.
temporary dimensions overlap |
Wed, Apr 15, 2015 at 1:31:29 PM
Visibility Problem - please help!!! |
Fri, Jan 11, 2008 at 10:20:02 AM
How to make Panels overlap Mullions & how to add gaps between those panels??? |
Sun, May 18, 2014 at 11:12:35 AM
Demolished walls overlap furniture in plan. |
Mon, Nov 26, 2012 at 1:08:02 PM
visibility problem with linked files |
Thu, Sep 11, 2008 at 11:52:11 AM
