Forums >> Revit Building >> Technical Support >> Getting DWF markup user to use VIEW not SHEET
Wed, Sep 4, 2013 at 6:19:15 AM | Getting DWF markup user to use VIEW not SHEET
SteveB
3.5 Stars: 5 Votes
Ive created a dwf with multiple sheets (an electrical set, in this example).  I sent it to a client who marked it up in Autodesk Design Review and sent it back to me.  I inserted it (insert/dwf markup) and it comes into the revit14 drawing file just fine but all the comments are on the SHEET and not in the view.  This is very inconvenined becuase I must open the view, make the change, exit the view, edit the dwf comment and repeat over and over.  How does one get/force the person doing the markup to work within the VIEW?
Wed, Sep 4, 2013 at 7:47:08 AM | Getting DWF markup user to use VIEW not SHEET
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I'm not sure if you can work in the view.  We just started using the DWF markups and we use 2 monitors so we can have the view and the DWF markup open.
Wed, Sep 4, 2013 at 7:56:04 AM | Getting DWF markup user to use VIEW not SHEET
SteveB
3.5 Stars: 5 Votes
you can have the markups in the view if you export to dwf just the view.  but that means the client/marker-up gets many separate view files.
Wed, Sep 4, 2013 at 8:20:12 AM | Getting DWF markup user to use VIEW not SHEET
Have you actually marked up something yourself?
I don't see how this is possible unless you only give the client the views and not on the sheets.  Of course then, he can't find his way around the set.
Revit no allowing me to save updates to DWF markup set
Thu, Oct 23, 2008 at 5:44:11 PM
turn DWF markup objects into Revit objects
Tue, Nov 9, 2010 at 8:31:09 AM
Visually Show DWF Markup as Completed
Thu, Jun 28, 2018 at 9:23:22 AM
DWF Linking
Thu, Aug 23, 2007 at 12:55:32 PM
Compiling Comment Logs in DWF
Mon, Nov 8, 2010 at 4:20:00 PM
Page generation time: 1.6545
