11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> First floor slab or ground floor ceiling?
Greetings,
I have built a smallish model which has a ground floor and a first floor above. The first floor 'ground' has been drawn as a concrete slab 300mm thick. Technically this same piece of concrete forms the structural ceiling/soffit of the ground floor also; but Revit (Arch 2013) does not appear to treat it this way. Is there a way that I can assign the underside of the first floor slab as the ground floor 'ceiling'? Or do I have to draw a separate ceiling for the ground floor?
Many thanks,
CM.
You can use the "generic" ceiling which has no properties but will host objects.
Splitting the ground floor slab? |
Thu, Dec 12, 2013 at 10:44:54 AM
Wall top vs. First floor slab |
Thu, Jul 8, 2010 at 10:40:55 AM
Window from floor above showing on ground floor plan |
Mon, Oct 10, 2016 at 7:13:10 AM
Ground Floor info. appearing on Second Floor |
Thu, Jun 9, 2016 at 2:24:40 PM
Creating drop panels to the underside of a sloped floor slab |
Fri, Feb 12, 2016 at 9:41:01 AM
