11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Topography Schedules and reporting Pad cut/fill.
I am having trouble creating a topography schedule that shows both the cut and fill created by a graded surface and the cut created by the pads.
How do we make a schedule that reports the name of the varoius topographies? There does not seem to be parameter for this? Does anyone have an example of one of these schedules orgive a quick step by step on hopw to create one?
Post edited on 2006-02-13 01:52:01
4 Posts No Rating |
We have done a similar thing (i hope) and in Your scedule, just make sure you have Name, (projected Area and Surface area if you like) (Fill, Cut if you'd like) and Net Cut/Fill, as the Schedule Fields in the Schedule Properties.
You can't name a Pad, but you will see them 'appear' in the Topo schedule, so to name them, you click on the piece of topo that 'walls' down/up to the pad, and then Properties and you can name that.
It should then appear on the schedule.
This is all only applicable if you have made the Topos correctly, (with one on the previous Phase etc.)
Hope this helps. Its a nightmare to get used to
Chris.
Topography - Cut and Fill for Graded Region |
Fri, Feb 4, 2011 at 11:31:15 AM
Topography Cut/Fill Schedule |
Thu, Nov 16, 2006 at 11:15:51 AM
Siteworks Cut & Fill |
Wed, Jun 1, 2011 at 5:12:56 AM
Cut into Topography |
Mon, Feb 19, 2007 at 8:55:23 AM
Building Pad Schedule |
Wed, Apr 23, 2008 at 11:12:39 AM
