Forums >> Revit Building >> Technical Support >> Schedules - Calculated Value does not have "Count" in the list of fields
Thu, Aug 29, 2013 at 1:42:40 AM | Schedules - Calculated Value does not have "Count" in the list of fields
BlueFairy
I'm trying to input the price for the number of fixtures in my schedule. I added "count" in the fields. However, when I try to create a calculated value, I dont see "count" to be inputted into the formula. Why wouldnt "count" be listed for the formula??
Thu, Oct 17, 2013 at 5:56:55 PM | Schedules - Calculated Value does not have "Count" in the list of fields
slyck
I had a similar proble trying to "count" to weight of some steel beams but I gave up trying this very approach.
In your case the solution may be found by inputting the unit price of each fixture by creating a "price" field in your schedules. Be sure to have the calculated totals for your price field and see what happens.
I hope this helps.
Thu, Oct 17, 2013 at 8:55:44 PM | Schedules - Calculated Value does not have "Count" in the list of fields
tanrevit
tanrevit Avatar
5 Stars: 2 Votes
Hi, make sure You checked on below
Room Schedules: Using "Count" in Calculated Vaules....???
Fri, Dec 10, 2010 at 1:02:21 PM
Window Schedule: "Count" not counting...
Tue, May 31, 2011 at 3:29:57 PM
Assembly Schedule: Part List - how to get "Volume" into avalible fields gialog?
Sat, Oct 29, 2011 at 2:39:47 AM
Schedule Count as Percent of Grand
Thu, Dec 22, 2011 at 10:33:17 AM
Schedules for Steel Tonnage
Thu, Oct 29, 2009 at 8:48:44 AM
Page generation time: 0.5757
