22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> LT2014 - Ceiling Based Model Disappears Halfway Across Raking Ceiling
3 Posts No Rating |
Hi Folks,
I am using a a ceiling based model light which for some reason disapears just after the halfway point of my ceiling, even though the models are aligned to the raking ceiling; th epitch is 8 degrees.
Any thoughts?
Did you look at your view range?
3 Posts No Rating |
Hey Mate,
Its not the view range, the model itself disapears into the ceilig as if it eases to recognize the ceiling workplane.
What do you mean by ceiling work plane? Ceiling hosted object are hosted on the ceiling.
If the model goes into the ceiling - THEN YOUR CEILING IS NOT RAKED!
3 Posts No Rating |
erm thanks, but the ceiling is set to a fall of 8 degrees; therefore it is a raking ceiling.
That aside, the ceiling does not seem to be hosting the light model past a certain point; approx halfway up the ceiling. Is there are parameter i need to add to the light model to ensure it's stays hosted to the ceiling?
Please post the light family you are using.
2D ceiling light object |
Tue, Jul 5, 2011 at 2:53:16 PM
Ceiling-based Components- Changing ceiling size |
Thu, Jan 5, 2012 at 9:39:52 AM
ceiling based component in sloping ceiling 2010 |
Tue, Nov 6, 2012 at 4:41:27 AM
Lines in Ceiling Plans |
Wed, Oct 24, 2007 at 4:44:57 PM
awkward shaped ceiling |
Fri, Mar 6, 2009 at 3:36:13 AM
