Forums >> Community >> Newbies >> Curtain Wall Grid Lines
Wed, Aug 28, 2013 at 10:30:00 AM | Curtain Wall Grid Lines
manb
Hi all,
I am new at Revit and I have a problem with deleting the grid lines. I have unpined it and click on delete, but it's still there and won't delete. Do you all have a solution?
I attached a pic, it's how the grid line still stand after the delete key.
Thanks for your replay. Smile
Wed, Aug 28, 2013 at 10:45:17 AM | Curtain Wall Grid Lines
Your curtain wall has an automatic spacing.  I always tell my users to change the CW to a fully manual type after initial placement so that it can be modified.
Wed, Aug 28, 2013 at 10:59:57 AM | Curtain Wall Grid Lines
manb
So I can't change aything now?
Or I have to place a new curtain wall with manual type, so i can modifie the cw then as i want?
Wed, Aug 28, 2013 at 11:13:55 AM | Curtain Wall Grid Lines
Change the CW to a manual type....Then you can delete the grid without any problems.
Mon, Sep 2, 2013 at 10:46:37 PM | Curtain Wall Grid Lines
renatolemus
yeap, select your curtain wall, in its properties there must be an option for changing the number of vertical and horizontal grid lines to a fixed number instead of a fixed distance, then you can change the number of segments in both axis
Tue, Sep 3, 2013 at 4:56:10 AM | Curtain Wall Grid Lines
manb
thank you all, it really helped me.
Edited on: Tue, Sep 3, 2013 at 5:01:12 AM
Curtain Grid Problems [ 1 2 ]
Wed, Apr 10, 2013 at 5:57:45 AM
19
How to edit a curtain wall grid in a curved and sloped surface
Wed, Dec 18, 2013 at 3:40:40 PM
Revit 2013 Curtain Wall Variable Grid Spacing
Thu, Jul 18, 2013 at 2:10:54 AM
Curtain Wall Grid Angle
Tue, Feb 15, 2011 at 2:42:32 PM
Curtain Wall runnning bond pattern
Fri, Nov 4, 2011 at 11:34:18 PM
Page generation time: 0.7888
