Forums >> General Discussion >> Revit Project Management >> Revit w/ Autodesk Showcase
Tue, Aug 27, 2013 at 11:25:06 AM | Revit w/ Autodesk Showcase
West1977
Hello all,
I've modeled a building in Revit and since exported a partial 3d section to Autodesk Showcase and applied the materials / colors to everything I need in order for the rendering to be sufficent for what I need and would like to supply the client.  Here's the question. Do most of you that use  Showcase (forgive me for my inexperience) export the image and then insert it into Revit to be printed with the rest of the sheets.  I guess my question is......after I Suite Workflow a revit model to showcase and get everything nice and pretty like i want, what's the best way to get that image back into my Revit file and inserted in onto my sheets to be printed on the same 30x42 sheet with the plan and/or elevations?  Do I just insert the image as I would any other image or is there a better way?
 thanks in advance for any advice available.
Edited on: Tue, Aug 27, 2013 at 11:26:44 AM
Autodesk Showcase
Wed, Aug 31, 2011 at 4:05:34 PM
Autodesk Subscriptions! Maintain or not?!?!?!?
Wed, Mar 6, 2013 at 5:38:22 AM
Autodesk Revit 6.1 is now available for download
Fri, Mar 12, 2004 at 9:08:45 AM
R E V I T C O M P O N E N T S . COM -- Open Source Revit Families
Thu, Mar 31, 2011 at 7:15:09 PM
help on rendering revit models in Autodesk VIZ
Sat, Jun 4, 2011 at 8:19:56 PM
Page generation time: 2.7807
