14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Can you join two roofs together that are linked?
I am working on a Townhome with two different models and then linking them together into one file. On one of the models the roofs are flush and you shouldn't see any lines when they are next to each other. I tried using the invisible line work tool in the main file to turn it invisible but I can't make the roof edge linework change. So, I'm trying to make the two roofs look like one continuous roof in the linked file, how can I achieve that?
nevermind, I figured it out.
If you ask a question then figure it out it is always nice if you can post your solution for others who may come across this problem.
Join Roofs not cutting roofs? |
Mon, Nov 28, 2011 at 6:53:31 PM
Roof problems with 2 gable roofs with different pitches. |
Sat, May 1, 2010 at 1:27:57 PM
Roof Join? |
Wed, Aug 11, 2004 at 6:44:42 AM
With roofs grouped, join roof tool not allowed |
Wed, Jun 20, 2012 at 2:37:50 PM
Problems joining roofs |
Fri, Apr 16, 2010 at 10:52:16 AM
