Forums >> Revit Building >> Technical Support >> Damaged & strange Room Color Scheme Revit 2013
Sun, Aug 25, 2013 at 4:22:26 AM | Damaged & strange Room Color Scheme Revit 2013
faisalhosny
Dear Team,
Please see the attached (jpg) file showing my plan created in Revit 2013, when I apply any room color scheme I found the room color very strange and it always changes with strange white color crossing lines reflected  from the previous location of the walls or the furniture when I Pan or Zoom in/out.
 I tried to open the plan on more than 4 different computers one of them very powerful:
NIVIDIA Quadro 6000
Intel(R) Xeon(R) CPU X5687 @3.60GHz (2 processors) , 192 GB of Installed (RAM)
Did anyone suggest any solution.
Notes:
1- I did not face this problem when I work on any of 2012 Revit version files.
2- When I activate [Use Hardware Acceleration (Direct3D) ] option the strange lines disappear but the work flow becomes very slow.
3- I face this problem on any project opened on 2013 version (Small or large size project)!
Thanks & Best Regards.
Sat, Sep 28, 2013 at 1:38:02 PM | Damaged & strange Room Color Scheme Revit 2013
mneglia
My thoughts...
Do you have any imported / linked CAD objects with hatches? Try removing them.
If you check under the graphics options in Revt, do you get a notice that you are not using the correct drivers?
Try auditing the file: http://bimeveryday.com/2013/02/audit-revit-files/
Revit blog: www.bimeveryday.com
Color Scheme Legend Issues
Mon, Dec 1, 2014 at 6:26:38 AM
color scheme disappear
Fri, Sep 24, 2010 at 7:49:22 PM
Color Scheme Problems
Tue, Jun 26, 2007 at 11:53:16 PM
color fill scheme showing up in entire building except one room.
Thu, Jan 16, 2014 at 9:45:17 AM
Room & Area Colour Scheme
Mon, Nov 24, 2008 at 10:37:48 PM
Page generation time: 1.7201
