Forums >> Revit Building >> Technical Support >> Stair Tread
Fri, Aug 23, 2013 at 1:39:40 PM | Stair Tread
rwood27
In Stair properties the nosing can run on the front and the sides.  However, it doesn't return into the side of the stairs?  Am I missing something?
Mon, Aug 26, 2013 at 9:20:19 AM | Stair Tread
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Not sure what you mean.  Post an image of your problem.
Mon, Aug 26, 2013 at 9:31:03 AM | Stair Tread
rwood27
Here's a shot.  If you notice the nosing as it meets the riser.  I want that profile to return to stair.  Don't tell me I have to Make a little sweep!  I actually wouldn't mind that on straight stair because it would be easy to array it but this stair is elliptical.
Thanks.
Mon, Aug 26, 2013 at 10:40:05 AM | Stair Tread
You can'd do that with the native stair.  Create a seperate family - face based.
How to model a non-typical length stair tread for the top tread
Mon, Jan 25, 2016 at 1:55:19 PM
Stair Riser/Tread Number in Multistory Stairs
Tue, Sep 13, 2016 at 9:47:54 AM
Custom Stair Tread Profile vs. Default Tread Profile
Tue, Apr 30, 2019 at 2:28:08 PM
Baluster per tread on curved stair
Thu, Apr 4, 2013 at 2:18:52 PM
Changing Stair Tread Shape
Thu, Sep 27, 2012 at 9:21:38 AM
Page generation time: 1.0602
