Forums >> Revit Systems >> Technical Support >> linked file visibility
Thu, Aug 22, 2013 at 2:01:40 PM | linked file visibility
vinnygolfer
4.5 Stars: 4 Votes
hi. i'm using Revit 2014. i have a background Revit file that has a linked autocad file for the structural. i'm having troubles with visibility. if i open the Arch background revit file, i see the structural in plan view, and 3d. however, in the mep model i only see the arch, and not the structural. if i use the reveal hidden elements button, the structural is there, but the button the unhide elements is greyed out. i have gone into VG and can't find any way to turn on the linked file. and when i export to navisworks the structural is there. i'm trying to turn it back on to route around the structure. any ideas.
Try to learn at least one new thing every day
Thu, Aug 22, 2013 at 2:48:28 PM | linked file visibility
Is it just 2D CAD?  If so, you may have something hiding it in your file.  Turn your view to transparent and see if it shows up.
Thu, Aug 22, 2013 at 2:54:52 PM | linked file visibility
vinnygolfer
4.5 Stars: 4 Votes
no the structural was is a 3d autocad file. it was showing up. and was in the way so i hid it in view. but now i can't get it to unhide. if i open the linked file by it's self the structural is there. and if i go into navisworks, it's there. i'm confused. if i use the reveal hidden elements button, i see the structural, but can't unhide it.
Thu, Aug 22, 2013 at 3:01:03 PM | linked file visibility
You may have this link turned off under the VG/Revit Links.
Try making a different plan view without a template.
....wait - you said you hid it....   temporary (sunglasses) ?  Must not be because it shows in reveal hidden.   Your problem is selecting it to unhide it.
Edited on: Thu, Aug 22, 2013 at 3:05:28 PM
Thu, Aug 22, 2013 at 3:21:45 PM | linked file visibility
vinnygolfer
4.5 Stars: 4 Votes
hi hub, attached are what i'm talking about. i did one in the normal 3d mode and the other is what i see if i use the reveal hidden elements.
Thu, Aug 22, 2013 at 3:23:00 PM | linked file visibility
vinnygolfer
4.5 Stars: 4 Votes
i don't know why only one of them attached, but here is the second.
Thu, Aug 22, 2013 at 3:33:17 PM | linked file visibility
vinnygolfer
4.5 Stars: 4 Votes
lets try that one again
Thu, Aug 22, 2013 at 4:09:53 PM | linked file visibility
Make a new 3D view!   Selecting linked CAD files in a linked Revit model would be hard to do.
Fri, Aug 23, 2013 at 7:35:56 AM | linked file visibility
vinnygolfer
4.5 Stars: 4 Votes
I tried making a new 3d view. no change. and yes it's a linked Autocad file, in a linked Revit file. i don't think it's possible. just a little more coordinating through navisworks to avoid the structure. or i can link the autocad file into the MEP Revit file also. i was trying to avoid that, because the structural base point is off in the X,Y, and Z directions. by about 100' each. they totally missed.
Fri, Aug 23, 2013 at 7:50:26 AM | linked file visibility
Vinny .... I WOULD link it in seperately and move it to where it belongs and in it's own workset that is normally off.   Then it won't even load with the linked architectural file.
Fri, Aug 23, 2013 at 8:05:11 AM | linked file visibility
#11
vinnygolfer
4.5 Stars: 4 Votes
thanks for the help. i was only using it that way, for ease of use downstream. i'm running the BIM coordination on the project, and suppling the subs with autocad files for background, and i loaded the arch/struct into navisworks for clash detection. it makes it easy to work with for that portion. but for my file it's not a good option. i just need to link it into my working file and be done playing around with it.
Linked File Visibility Management
Thu, Jan 3, 2008 at 6:11:30 AM
Visibility of linked revit file in different views?
Wed, Jun 14, 2017 at 1:11:18 PM
Sat, Mar 4, 2006 at 3:53:07 AM
Linked File, how can I dimension it?
Sun, Dec 19, 2010 at 8:08:50 PM
visibility problem with linked files
Thu, Sep 11, 2008 at 11:52:11 AM
Page generation time: 2.4411
