Forums >> Community >> Newbies >> Title block labels not appearing in projct
Wed, Aug 21, 2013 at 5:44:43 PM | Title block labels not appearing in project
lukedemeur
Hi,
I am in the process of setting up title blocks for our company but I am finding some labels are not appering when I load the title block in a project. Namely the Scale, Revision and file path parameters are not showing up. The others like sheet name, sheet no, drawing no, project tilte, designed and drafted etc....all work fine no problems when I load into the project, I dont understand??
I am not talking about custom parameter labels, I have figured out how to do that and they work fine, these are just the stock standard label parameters. This also happens when I load in a standard Revit title block that comes with revit, those parameters just dont show up for example the scale is just not there, when I go into the family for that standard revit title block its all there but its just not showing up in the project.
I have not found any post like this in searching around on different forums, there is plenty on custom label parameters but nobody seems to have this problem with the stock standard label parameters. Any Ideas??
Thanks
Edited on: Wed, Aug 21, 2013 at 8:06:15 PM
Edited on: Wed, Aug 21, 2013 at 8:06:53 PM
Thu, Aug 22, 2013 at 7:28:48 AM | Title block labels not appearing in projct
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Did you put a view on the sheet for it to read?  Did you add a revision to the project?
Thu, Aug 22, 2013 at 7:37:05 AM | Title block labels not appearing in projct
Without seeing your family, I doubt we can help you very much.  We have created our own sheets and the process works when done correctly.  Make sure you are using the correct process.  I just created a different titleblock with the project path last week so I know that works as well.
the stock titleblock doesn't work, then something is wrong with your installation.
What Revit?  What update?
Thu, Aug 22, 2013 at 5:36:25 PM | Title block labels not appearing in projct
lukedemeur
Thanks Guys,
It's all good...Being such a newbie I did not realise those parameters where dependent on actually placing a view and adding a revision stupid!  It all works well.  Thanks again for your time.
Title Block labels
Sun, Apr 8, 2007 at 10:04:03 PM
Title Block Labels
Wed, Feb 14, 2007 at 11:52:49 AM
Title Labels [ 1 2 ]
Sat, Jun 29, 2013 at 12:54:18 PM
15
Labels in title block literally gone in project
Thu, Nov 20, 2014 at 8:22:22 AM
Title block labels
Thu, Sep 23, 2010 at 6:09:42 PM
Page generation time: 0.1213
