Forums >> Revit Building >> Technical Support >> Revit 2014 - We need a sketchy rendering style workflow - Any suggestions???
Wed, Aug 21, 2013 at 2:56:38 PM | Revit 2014 - We need a sketchy rendering style workflow - Any suggestions???
caliphile
Hey all.  In the past our office has found good success with some clients showing sketchy style renderings early in the design process.  My research on this forum and others suggests that there is not a seamless way to do this in Revit (bummer).  We've tried using Illustrator and had mixed results - better for plans than three dimensional views.  Ideally a sketch-up style would be nice.
Any good workflow recommendations?
Thanks in advance!
-Drew
Wed, Aug 21, 2013 at 3:00:21 PM | Revit 2014 - We need a sketchy rendering style workflow - Any suggestions???
You were given a copy of impressions with your Revit.  Your answer is with that program.
Wed, Aug 21, 2013 at 4:07:36 PM | Revit 2014 - We need a sketchy rendering style workflow - Any suggestions???
caliphile
I used a demo copy of impressions years ago but thought that the program was discontinued.  I didnt see it bundled with Building Design Suite 2014 and the only info I can find on the autodes website is from 2009.  Is it still current/supported/compatible with BDS 2014?
Thanks!
Thu, Aug 22, 2013 at 5:21:14 AM | Revit 2014 - We need a sketchy rendering style workflow - Any suggestions???
coreed
coreed Avatar
4 Stars: 16 Votes
Try exporting your Revit models to .dwg and bring into SketchUp
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Thu, Aug 22, 2013 at 7:54:45 AM | Revit 2014 - We need a sketchy rendering style workflow - Any suggestions???
Your right, they have not upgraded Impressions but our last Impression3 still works because Impressions doesn't use the Revit file.
Revit to Sketchup Workflow...
Tue, Mar 1, 2011 at 6:56:43 AM
my first rendering, need some suggestions
Wed, Jan 5, 2005 at 7:25:50 PM
Looking for Rendering Suggestions on a Revit 2008 Accurender Rendering..........
Wed, Nov 4, 2009 at 4:41:36 PM
Efficiency in Revit Workflow
Tue, Apr 7, 2015 at 7:49:57 AM
Model gone sketchy in 3d?
Wed, Oct 15, 2008 at 8:48:48 AM
Page generation time: 1.5661
