Forums >> Revit Building >> Technical Support >> section markers remian highlighted
Tue, Aug 20, 2013 at 4:49:58 PM | section markers remian highlighted
cw202t
I am sure there must be a way to deacdivate the section heads. I would apprecaite any advice. I am trying to export a sheet as a dwg file and it locks up. I hide in view the section heads and it works.
Wed, Aug 21, 2013 at 7:17:59 AM | section markers remian highlighted
Something else is wrong here because this should never happen and we have never heard of this problem.  Maybe the file is corrupted - audit the file.
BTW - You do not say what Revit issue  - you should always include that in your post as well as what the last update you have installed is.  Make sure you have the latest updates installed.
Wed, Aug 21, 2013 at 8:12:19 AM | section markers remian highlighted
cw202t
Thanks, I'll let you know how it pans out.
I am using Revit Lt 2014
Scaling section and elevation markers
Thu, Jul 26, 2012 at 7:13:35 AM
Elevation Markers, Level Heads, Section Markers, all at Varing Scales
Mon, Feb 20, 2012 at 11:33:58 AM
Red Section Markers
Thu, Feb 28, 2013 at 8:13:10 AM
Rev 2009 Section Markers
Wed, Aug 17, 2011 at 8:25:09 AM
Section marks show up in all views
Mon, Jul 21, 2025 at 8:03:45 PM
Page generation time: 0.1964
