Forums >> General Discussion >> Revit Project Management >> Project Linking Question
Tue, Aug 20, 2013 at 11:19:56 AM | Project Linking Question
majk1701
We're a small mep firm that is currently working with (2) Architectural firms. One firm is doing the office areas (that are outcroppings) and the other is doing the main warehouse area (which the outcropping areas are attached.
My question is this:
What is the best linking strategy, should all office areas be linked into the main warehouse area then this model would inturn be linked into our mep model, or would you link each individual office area into our mep model as well as the main warehouse area?
Additionally, is there any reason the firm responsible for the office areas wouldn't have these offices in 1 model and not broken up into 4 seperate models that have to be linked in seperatly?
Tue, Aug 20, 2013 at 11:22:01 AM | Project Linking Question
majk1701
Sorry, the hightlighted areas on the attachment are the office areas.
Tue, Aug 20, 2013 at 11:43:29 AM | Project Linking Question
There is no reason why I would have done these as seperate architectural models.
I think I would link each one into your MEP file - no reason for an intermediate file.
Tue, Aug 20, 2013 at 11:54:20 AM | Project Linking Question
majk1701
So you also have to copy/monitor each level in each seperate link, correct?
Tue, Aug 20, 2013 at 12:03:30 PM | Project Linking Question
Ah.... I see where you are going.
Are they at different physical elevations and may change?  If so then obviously yes.
If not ... if they can't move independently, then one set would do it.
A bigger problem may be column grids.  If each project has a grid A then you are in trouble.  I have not experienced this and I don't know how Revit will handle that.   You may have some serious problems.
Tue, Aug 20, 2013 at 12:18:30 PM | Project Linking Question
majk1701
There's one structural column grid model that's linked into each model, is this what your asking? Sorry new to this type of project enviornment.
Tue, Aug 20, 2013 at 12:35:00 PM | Project Linking Question
majk1701
Sorry not sure why it posted same reply multiple times?
Tue, Aug 20, 2013 at 12:45:52 PM | Project Linking Question
I delete multiple posts when I see them.  I believe they are caused by you using your back or possibly refresh buttons.
If the architect had sense enough to use one grid scheme - why not levels as well?
So now you have to link the grid model as well.........
Edited on: Tue, Aug 20, 2013 at 1:17:54 PM
Tue, Aug 20, 2013 at 1:13:29 PM | Project Linking Question
majk1701
You are corect (unfortunatly!!) Thks for your expertise!
Linking models with multiple sites
Wed, Dec 6, 2017 at 9:43:09 AM
Linking Revit Files for Sheet Coordination
Fri, Jul 10, 2009 at 11:09:09 AM
Linking large files
Wed, Aug 31, 2005 at 2:32:01 PM
Project Management - Linking vs Worksets
Wed, May 30, 2012 at 6:41:37 AM
DWG linking into revit
Mon, Jun 9, 2014 at 7:11:38 AM
Page generation time: 0.6399
