Forums >> Revit Building >> Technical Support >> stacked walls not editable
Sat, Aug 17, 2013 at 1:11:09 PM | stacked walls not editable
Wader
I have a couple of stacked walls that I cannot change to different wall types or even delete......I continue to get an error message that says  "Cannot extend layer(s) of the highlighted vertically compound wall"...I can't do anything to them except detach them from the roof or break them into parts.......neither of which  solve my problem.  At one point I grabbed the outer two layers of the wall at the base and extended them down to the foundation but I have since re-aligned them with the rest of the wall layers.  Not being able to alter them is stopping me dead in my tracks.
thanks
Sat, Aug 17, 2013 at 1:23:37 PM | stacked walls not editable
Wader
I just found out that there is an adjacent interior (non stacked) wall that I am having the same issues with...all three problem children are joined at the same corner...non can be altered or erased. #$%%^$%
Help
Sat, Aug 17, 2013 at 1:27:27 PM | stacked walls not editable
Wader
Never mind...I found a fix....somehow the two stacked walls and the two interior walls were creating a funky joined condition with the floor and once I deleted the interior walls, the exterior wall could be deleted.
Titleblock with 2 stamps and editable text stacked?
Mon, Jan 3, 2011 at 9:36:13 PM
stacked walls
Mon, Sep 10, 2018 at 9:55:14 AM
stacked walls
Tue, Nov 25, 2014 at 5:51:10 PM
Dimension Stacked Walls
Thu, Aug 18, 2011 at 12:23:35 PM
Temporary dimensions and stacked walls
Wed, Feb 9, 2011 at 8:47:10 AM
Page generation time: 0.5965
