20 Users Online (18 Members):
Forums >> Revit Building >> Tips & Tricks >> chamfered beam visibility
I have created a beam with chamfered ends using void extrusions. I would like to know if there is a way to turn the chamfered ends on or off?
If the voids are located parametrically (lets say up/down) with an instance based location (reference plane), you can move the voids off the beam in the model.
I am not sure I follow. I created a reference plane to locate the distance from the top of the beam where the chamfere will begin.
I am going to try to attach the beam to this reply.
Put this family in a model - plan view. Now click on it and drag the grips in the center of the hole up and watch what happens. Open the family and see how it is constructed.
I forgot to mention that I am using revit 2013. when I tried to open the fiile that you attached it said it was in a later version.
Well - I don't have time to recreate that - you should always state what you are using in all posts.
Beam System Visibility |
Wed, Mar 22, 2006 at 9:23:08 AM
VG problems with uploaded beam family |
Tue, Aug 28, 2007 at 6:49:43 PM
Chamfered edge timber plinth |
Mon, Jun 27, 2011 at 9:52:33 AM
Stuctural beam extension visibility |
Wed, Mar 7, 2007 at 5:27:12 PM
Structural Beam Visibility |
Tue, Feb 27, 2007 at 11:37:36 AM
