Forums >> Revit Building >> Technical Support >> Changing Revit to Imperial
Wed, Aug 14, 2013 at 4:27:56 PM | Changing Revit to Imperial
pleasemayouhelpme
Hi, I was wondering if anyone could give any suggestions on how I could change Revit from metric to imperial as I am working on an old building which is in imperial. I am in Canada and Revit is automatically in metric.
Thanks,
Thu, Aug 15, 2013 at 12:05:41 AM | Changing Revit to Imperial
ronmalit
5 Stars: 3 Votes
hi
hope this is allowed here, but you can refer from this link:
http://forums.augi.com/showthread.php?136539-HELP-Changing-Revit-units-from-imperial-to-metric
** dont be mad, i dont have much... i am homeless
Thu, Aug 15, 2013 at 3:47:32 AM | Changing Revit to Imperial
mansell5
3.5 Stars: 4 Votes
to change units click on manage tab then project units tab.
a dialogue box opens offering alternatives.
under project units click on the narrow boix next to length (it would say 1235[mm]   )
change it to feet and fractional inches or fractional feet etc, your choice.
click ok to exit and you should be in metric.
cheers
geoff
Thu, Aug 15, 2013 at 7:48:30 AM | Changing Revit to Imperial
Remember - changing the project units will not change any annotations that are set to something other than project units.
Thu, Aug 15, 2013 at 9:43:50 AM | Changing Revit to Imperial
pleasemayouhelpme
Thanks, I'm new though, so could you help me in simipler terms maybe? Also is there a way to only change the mesuring tool to imperial?
Thu, Aug 15, 2013 at 9:50:28 AM | Changing Revit to Imperial
pleasemayouhelpme
I was reading somewhere else, that I should change it in manage project units. I only really need the mesuring tool to be in imperial  though. Also this is for piping,
Please help me and thanks in advance.
Thu, Aug 15, 2013 at 10:02:05 AM | Changing Revit to Imperial
pleasemayouhelpme
NEVER MIND, turns out I didn't need to after all, thanks for the great help though!
Distance Inquiry In Imperial On Metric Project
Fri, Aug 8, 2014 at 9:05:58 AM
Change from Metric to Imperial
Sun, Feb 17, 2013 at 9:26:03 AM
Imperial Projects and Families help needed
Wed, Dec 10, 2014 at 12:53:43 PM
Change imperial to metric
Wed, Mar 11, 2009 at 9:20:24 AM
showing metric and imperial elevations
Thu, Jun 3, 2010 at 3:34:46 PM
Page generation time: 2.8902
