13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Unable to end commands/exit edit mode
1 Posts No Rating |
I'm using Revit Architecture 2012, of course with a project due, and am experiencing a problem that has completely halted any output. It seems that when I attempt to form a floor, or stairs, or any command of that nature, the only way to end the comman d, or exit edit mode is to ctrl-z my way back to nothingness. Esc doesn't seem to cut it. I have an important project due yesterday, any help would be mucho appreciated. Thanks
last time we encounter ribbon problem in our 2013, coz we install 2014. the update release for 2013 help solved that..
its worth trying it: http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9273944#section3
it seems you got a ribbon issue also, because the only way to exit sketch mode is to click X or CHECK and to end command is to click the ARROW below application menu. (except escape and CTRL+Z)
** dont be mad, i dont have much... i am homeless |
Hotfix - Autodesk Revit 2012 - Ribbon behavior due to .Net 4.5 installation
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21344242&linkID=9273944
For future reference, you can cycle throgh menus by double clicking on the tab bar (Revit -dark grey bar at the top).
Edited on: Wed, Aug 14, 2013 at 7:30:07 AM
Can't exit sketch mode |
Tue, Oct 22, 2019 at 7:19:00 AM
Stairs Disappear upon edit sketch mode. |
Wed, Jun 6, 2018 at 12:49:18 PM
group edit mode |
Mon, May 27, 2013 at 8:32:56 AM
Question about sketch Mode |
Thu, Jan 17, 2013 at 6:34:56 PM
Concrete Beams |
Tue, Nov 11, 2008 at 3:33:21 PM
