Forums >> Revit Building >> Technical Support >> trimming vertical mullions to continuous border mullion
Tue, Aug 13, 2013 at 12:04:32 PM | trimming vertical mullions to continuous border mullion
sfountain
(Revit 2014)
I'm doing a little experimentation with curtain walls, and I'm wondering if there is a way to keep the border mullions
continuous, yet still have interior mullions trim to them? for this particular situation, the border mullions have a sloping
face, so if the borders are kept continuous, then the interior mullions leave a gap between its edge and the sloping face
of the border ..I would like to be able to trim them to the border i guess...hopefuly the attached file helps clarify..
thanks!
Tue, Aug 13, 2013 at 1:18:15 PM | trimming vertical mullions to continuous border mullion
The only way I have seen this done is with two curtain walls.  One has everything except no vertical mullions at the grids and another CW in the same place that has empty system panels and only vertical mullions.
Tue, Aug 13, 2013 at 2:05:14 PM | trimming vertical mullions to continuous border mullion
sfountain
Interesting..hadnt thought of that at all...i'll give it a shot.
'preciate it!
Tue, Aug 13, 2013 at 5:28:05 PM | trimming vertical mullions to continuous border mullion
sfountain
here's what i get when i combine two curtain walls...a little sloppy in 3d and elevation, but looks fine in section.
thanks again
Creating a vertical continuous mullion with a profile edited curtainwall
Tue, Mar 22, 2016 at 10:46:17 AM
Curtain Wall Mullion Tools
Wed, Apr 13, 2005 at 1:00:25 PM
Curtain wall panels not trimming correctly against mullions
Thu, Dec 10, 2009 at 5:49:55 PM
continuous vertical and horizontal custom mullion system
Wed, May 21, 2014 at 8:53:49 AM
Custom Curtain wall mullions...please help!!!!
Sat, Apr 25, 2009 at 8:36:15 AM
Page generation time: 0.2335
