Forums >> Revit Structure >> Technical Support >> AutoCAD File import in Revit Visual style (Shade) Problem
Tue, Aug 13, 2013 at 2:40:23 AM | AutoCAD File import in Revit Visual style (Shade) Problem
caddeva
Hi All,
I am a structural professional. i am using ASD-2013 (Autocad Structural Detailing) and Revit structure 2013. the problem comes here,when i complete the 3D modelling in ASD and imported to revit. the imported model has to be exposed as " WireFrame" mode.  i've trying to change the "Visual Style: Shade with Edges" it won't be worked out.  it's looks for itself. Any specfic settings and options in ASD or RST to get Shade with Edges in RST.
Problem import Autocad file that contains ''proxy entities''.
Wed, Mar 17, 2021 at 7:38:19 AM
import to revit from autocad
Sun, Mar 31, 2013 at 11:37:12 AM
Hatch and background in hidden line visual style
Wed, Nov 10, 2010 at 10:02:09 AM
Autocad Import Problems
Tue, May 5, 2009 at 1:55:33 PM
dimension change when importing AutoCad file
Thu, Oct 16, 2014 at 10:59:01 AM
Page generation time: 3.7915
