Forums >> Revit Building >> Technical Support >> Add Yes/No Instance Parameters to Test
Mon, Aug 12, 2013 at 10:53:34 AM | Add Yes/No Instance Parameters to Test
cboersen
Revit Architecture v2013
In a Component I am creating I have a line of text that I want to be able to turn on and off with a Yes/No Instance Parameters.  How do I do that?
Mon, Aug 12, 2013 at 11:05:38 AM | Add Yes/No Instance Parameters to Test
Model text in families can be controlled just like other model elements.
Mon, Aug 12, 2013 at 2:59:08 PM | Add Yes/No Instance Parameters to Test
cboersen
I should have mentioned this as well, but I did not think of this at first.  Because it is a title block/sheet I do not believe it has model text (or lines).  I have an example here of one that someone did it with just lines and text in a title sheet but I cannot figure out how.
Mon, Aug 12, 2013 at 3:08:49 PM | Add Yes/No Instance Parameters to Test
We have a preliminary "stamp" in our titleblock which is an annotation symbol (text plus lines) with visibility being a type driven switch.
Mon, Aug 12, 2013 at 3:13:03 PM | Add Yes/No Instance Parameters to Test
cboersen
Exactly whay I am looking to do.  That is not model text or lines as far as I can tell so how do you add a Yes/No Instance Parameters to those?  Or am I missing something really stupid.
Mon, Aug 12, 2013 at 3:43:59 PM | Add Yes/No Instance Parameters to Test
I just told you!  It is a seperate family (annotation symbol) loaded into the titleblock and the visibility of that item is set to a y/n switch.
Instance Parameters Resetting
Mon, Jan 28, 2019 at 1:20:31 PM
Adding Parameters to Walls
Fri, Mar 15, 2013 at 10:26:04 AM
Instance Parameters [ 1 2 ]
Wed, Aug 15, 2007 at 6:10:55 PM
16
INSTANT PARAMETER SCHEDULEABLE
Wed, Jul 11, 2012 at 12:26:36 PM
Deleting Door Instance Parameters
Fri, Oct 17, 2008 at 8:58:06 AM
Page generation time: 0.4232
