Forums >> Revit Building >> Technical Support >> Using instance parameter in type parameter formulae
Mon, Aug 12, 2013 at 8:15:36 AM | Using instance parameter in type parameter formulae
sabari2504
Hi,I understand that I can't use instance parameter in type parameter formulae. But is there any work-around so as to get my yes/no visibility parameters, which are used in type parameter formulae, as tick-boxes in the properties side-panel at the project level?Thanks in advance.
Mon, Aug 12, 2013 at 8:22:38 AM | Using instance parameter in type parameter formulae
The properties panel does not show type parameters.....and it looks like you understand that.
Parameter Formulae - Moment of Inertia
Thu, Apr 9, 2009 at 1:17:35 PM
Titleblock Parameter is now Instance instead of Type
Tue, Feb 17, 2015 at 3:31:00 PM
System Parameter - Modify instance to type?
Fri, Jan 22, 2016 at 2:01:16 PM
Instance Parameter to control another Instance Parameter
Thu, Jul 22, 2010 at 6:22:48 AM
Instance Parameter connected to a Visibility Parameter for Scheduling Purposes
Wed, Mar 7, 2012 at 5:53:46 PM
Page generation time: 2.7739
