Forums >> Revit Building >> Technical Support >> Wall sweep won't trim
Sun, Aug 11, 2013 at 4:04:45 PM | Wall sweep won't trim
Wader
I have an exterior CMU wall with sweep at the wall base added in the wall type. I have edited the shape of the wall, creating
a "hole" to allow another wall and windows to show through, but the sweep extends through the inset wall.  I've joined the two walls
but can't seem to figure out how to get the sweep to cut at the inset wall.
thanks for any suggestions
Sun, Aug 11, 2013 at 6:59:25 PM | Wall sweep won't trim
I don't use embedded sweeps because of the problems they have.  Use an applied wall sweep instead.
Sun, Aug 11, 2013 at 9:54:17 PM | Wall sweep won't trim
ronmalit
5 Stars: 3 Votes
Hi,
another way is to convert wall into parts, divide it and exclude the window area from the part.
** dont be mad, i dont have much... i am homeless
Mon, Aug 12, 2013 at 7:21:52 PM | Wall sweep won't trim
Wader
Thanks...I was afriad there was no easy solution.....it looks like sweeps cannot be partially cut by windows or doors
no matter how you apply them.  They are either broken the full height of the sweep or not at all.
Fri, Aug 23, 2013 at 11:42:18 PM | Wall sweep won't trim
pchan
pchan Avatar
5 Stars: 5 Votes
Create a face based family with a void that cut out the extrusion (within the face based family itself), use the family on the integrated sweep and you can cut out the sweep. In this case, you would want to make the face based family to be parametric so the you can use it for more than one location for different sizes.
Tue, Apr 25, 2017 at 2:07:17 PM | Wall sweep won't trim
anablaze
Hi
You can divide your sweap to parts and then
delete the part you don't need
Trim and frame does not adjuts to wall as expected
Wed, Mar 1, 2006 at 12:22:56 PM
Line Based Family Won't Join at Ends
Mon, Apr 10, 2023 at 8:13:57 AM
Wall Sweep only cuts out window not trim
Mon, Aug 18, 2014 at 10:34:16 PM
EIFS Wall sweep won't attach
Mon, Jun 10, 2013 at 7:48:47 AM
trim sweep for ceiling?
Fri, Jun 21, 2013 at 12:41:43 PM
Page generation time: 0.9312
