Forums >> Revit Building >> Technical Support >> why do my text look wonky when I make pdf files?
Fri, Aug 9, 2013 at 12:46:04 PM | why do my text look wonky when I make pdf files?
BlueFairy
My texts look fine when I look at the revit files but when I finally make pdf files some of the letterings look wonky. How do I fix this? is this Revit or is this the problem with the pdf creator?
Fri, Aug 9, 2013 at 12:51:53 PM | why do my text look wonky when I make pdf files?
We don't have enough knowledge to answer your question.  Our pdf's are fine.
Your letterings look "wonky".... on the screen? ... when you print?
We use:
Mon, Aug 12, 2013 at 12:22:06 PM | why do my text look wonky when I make pdf files?
arkoh
I had the same problem as you, and it turned out to be the pdf writer I had installed... and a few settings there that solved the issue!
Hope you figure it out!
settings for pdf files
Fri, May 25, 2012 at 8:39:25 AM
Text at 45 degree not right in PDF
Thu, Oct 1, 2015 at 6:47:55 AM
Text Background Mask Disappearing in PDF's (Revit Architecture 2009)
Thu, Feb 12, 2009 at 1:29:29 PM
printing PDF files
Sun, Mar 13, 2016 at 12:33:02 PM
Print entire projekt to single pdf files
Mon, Sep 6, 2010 at 7:58:08 PM
Page generation time: 2.1474
