Forums >> Revit Systems >> Technical Support >> Help with a family we made that doesnt work correctly all the time (P-trap)
Thu, Aug 8, 2013 at 1:47:43 PM | Help with a family we made that doesnt work correctly all the time (P-trap)
jcrocco
3 Stars: 1 Votes
I have this P-trap family that I frequently have issues with, and was wondering if someone can help with a solution, if there is one.  Also, everyone can copy this file for your own use if interested.  Maybe someone can help to fix it and post the fix for all to use, or is there one already that exists?
Some of the issues are the ptrap gets installed in the wrong direction, based on how you select the pipes, and sometimes on how the pipes where drawn.  We change the ell to the ptrap fitting, then if its wrong, delete the ptrap fitting, then reconnect the verticle to the horizontal pipe then replace the ell again with the ptrap.  It would be nice for it to always go in right the first time.
Also, sometimes if the pipe the ptrap is on is modifed, or moved, or repitched, it will cause the fitting to be redrawn, and sometimes goes back in the wrong direction.
Any advice or a working ptrap would be greatly appreciated.
Thu, Aug 8, 2013 at 3:44:59 PM | Help with a family we made that doesnt work correctly all the time (P-trap)
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Try hitting your spacebar before clicking the placement point. It will cycle thru different basepoints in the fixture family. I also find you have to wiggle your mouse a round as you do it for the graphics to update real time.
This works for pipe, conduit and duct fixtures.
Trap Primer Family
Thu, Jan 3, 2013 at 4:50:21 PM
Modifying a family
Thu, Mar 12, 2009 at 2:48:56 PM
Log Cabin Trap Windows
Sun, Sep 21, 2008 at 9:02:21 AM
Made a new family but ant rotate it properly
Mon, Jun 13, 2011 at 12:32:45 PM
materials parameter doesnt work in project.
Fri, Jul 24, 2009 at 10:32:02 PM
Page generation time: 4.4156
