16 Users Online (15 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> View References issue in 2013
Thu, Aug 8, 2013 at 11:15:51 AM | View References issue in 2013
guero6171
I have created a matchline in Revit Architecture 2013 and assigned view references to either side of that line.  The relative views have been placed on their respective sheets which are named and numbered.  Unfortunately, the references will not register the relative sheet numbers.  They still just say 'Ref', although in the properties panel it shows that these references clearly know what sheet to reference......it just won't display the reference.
I have even tried shutting Revit down and restarting in case it was a simple glitch....no such luck.  Can anyone help, please?
Thu, Aug 8, 2013 at 12:03:18 PM | View References issue in 2013
It sounds like that reference family has been modified.  Edit that family.
Thu, Aug 8, 2013 at 1:10:18 PM | View References issue in 2013
guero6171
Thanks WWHub, but I can see no way to edit this reference family.  Edit Type offers nothing either. Please pardon me, I am still a relative novice.
View References in Text and Keynotes
Fri, May 22, 2015 at 1:05:20 PM
Detail References
Mon, Sep 24, 2012 at 8:26:51 AM
View References... how do they work?
Wed, Feb 27, 2008 at 3:00:42 PM
Spot Dimension references are no longer valid
Mon, Dec 3, 2012 at 7:44:16 PM
Errors regarding dimensions when opening
Tue, Mar 6, 2012 at 1:07:27 PM
Page generation time: 5.3023
