Forums >> Revit Building >> Technical Support >> Revit freezes when I do a 'Save As'???? Need help urgently!
Thu, Aug 8, 2013 at 10:14:23 AM | Revit freezes when I do a 'Save As'???? Need help urgently!
joffutt1
Whenever I am in a family or a project and want to do a Save As, once I click on the option it freezes and no dialog box appears.  The program isn't truly frozen and will "unfreeze" once I hit escape.  I've upated with service packs and nothing helps.  Restarted the computer, still nothing.
Can anyone help???
Thu, Aug 8, 2013 at 10:20:38 AM | Revit freezes when I do a 'Save As'???? Need help urgently!
4 Stars: 205 Votes
Wierd... what version of Revit? Did you updated your Graphic card drivers ?
Thu, Aug 8, 2013 at 10:43:41 AM | Revit freezes when I do a 'Save As'???? Need help urgently!
Are you saving from tiled views?  << Don't do that!
Thu, Aug 8, 2013 at 11:08:12 AM | Revit freezes when I do a 'Save As'???? Need help urgently!
joffutt1
I have Revit 2013.
No, whenever I try to save as from a simple family type it won't allow me the option either.
Thu, Aug 8, 2013 at 12:01:44 PM | Revit freezes when I do a 'Save As'???? Need help urgently!
There are strange things that happen sometimes because of the operating system still limited by old rules.  Try this - run CCleaner and let it clean up your temp files.  Please let us know if that works.
Fri, Aug 9, 2013 at 10:53:11 AM | Revit freezes when I do a 'Save As'???? Need help urgently!
joffutt1
I tried the CC Cleanup.  It didn't work.  :-(
''Visibility grafics'' and ''create parts'' problem when mak
Fri, Mar 19, 2021 at 11:45:46 AM
'save as' reduces file size - a good method?
Tue, Sep 23, 2014 at 7:36:45 AM
Revit Freezes
Wed, Nov 23, 2005 at 6:09:57 PM
RPC's won't render in 3DS Max after importing from Revit
Sat, Dec 17, 2005 at 9:10:50 AM
Archiving worksets
Thu, Sep 1, 2005 at 1:14:55 PM
Page generation time: 1.4405
