Forums >> General Discussion >> Revit Project Management >> Revisions on sheets Not Showing
Wed, Aug 7, 2013 at 3:02:17 PM | Revisions on sheets Not Showing
liebke
Sorry in the first post didn't include the second screen shots;
Hi to all, I have try all I know trying to fix mi revision issued in the sheet title,
 My problem is that for some reason in my project when I try to make issued dates to work, it does not show the information, I attached an screen shot of it, one is in a new sample project that show correctly and the other is not showing correctly.
Please can somebody give me any suggestion how to fix?
Thanks'
Edited on: Wed, Aug 7, 2013 at 5:44:02 PM
Edited on: Wed, Aug 7, 2013 at 5:52:51 PM
Wed, Aug 7, 2013 at 3:26:56 PM | Revisions on sheets Not Showing
Please do NOT create multiple threads on the same subject.  Once you start a thread - add to it if you need to - don't create another.
Also - Your images don't do anybody any good because we can't open them to see them.  Use the file attachment under the message window.
I am deleting your first thread.
Wed, Aug 7, 2013 at 5:29:01 PM | Revisions on sheets Not Showing
liebke
Sorry about, wwhub,..can you guide me how to add tread to the same treads, please?..never mind, found how to do,..thanks
Edited on: Wed, Aug 7, 2013 at 5:54:27 PM
Thu, Aug 8, 2013 at 7:59:28 AM | Revisions on sheets Not Showing
The problem may be  your title block family.  To create the schedule, did you follow the process as described in your HELP?
http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/1468-Document1468/1926-Prepare_1926/1956-Title_Bl1956/1963-Revision1963/1964-Adding_a1964
Thu, Aug 8, 2013 at 10:01:54 AM | Revisions on sheets Not Showing
liebke
yes WWhub, I follow all step by step; the title family is working ok, I tested the family by loading in a new project and it works,
is just in my project that i show in the pPdf file that is not working, i spend a lot of time setting up and i dont want to lose that file.
thanks for answer
Thu, Aug 8, 2013 at 10:38:52 AM | Revisions on sheets Not Showing
I want to make sure you are testing correctly.  You post two images, one where you say it works and one where it does not.  Did you put this title block in the project where it works?
Is that image with your titleblock?  That answer is no because the clouds are different.  Put your titleblock in that project.  I need proof that it isn't your titleblock.
Also, do a sheet list schedule with
  1. Sheet number
  2. Current Revision
  3. Current Revision date.
add show us that image.
Thu, Aug 8, 2013 at 1:47:58 PM | Revisions on sheets Not Showing-curse
liebke
WWhub,
1)      yes I have mi Title block loaded in the two projects, one I named "Project test" and the other " My project".
2)      I create 3 different cloud revisions with the respective tag to allow to see if the Revisions work properly in both projects.
3)      In the "Project test" the revisions works fine as you can see the screen shot, insert the sheet list also, please see the PDF file
i
Thu, Aug 8, 2013 at 4:07:04 PM | Revisions on sheets Not Showing
Sorry then you apparently have a corrupted project.  Have you run the audit?  If not then do that first.
If that doesn't clear the problem, give it to AutoDESK.  Their response is just about one day.
revisions showing up when they are not supposed to (2019)
Wed, Jul 17, 2019 at 7:39:37 AM
revision schedule different sheets
Wed, Feb 18, 2009 at 3:03:51 AM
Showing 2 Revisions in Revision Schedule
Tue, Apr 17, 2012 at 4:06:16 PM
Showing All Revisions in One Schedule
Thu, Feb 14, 2013 at 3:37:15 PM
views and sheets for revisions [ 1 2 ]
Fri, Mar 11, 2011 at 9:21:39 AM
20
Page generation time: 1.1469
