Forums >> Revit Building >> Technical Support >> Revit Monolithic Stair with Material Finishes
Wed, Aug 7, 2013 at 7:49:35 AM | Revit Monolithic Stair with Material Finishes
tkahng
Hello,
I am currently using Revit 2014 Student Version, and am attempting to build a concrete flight of stairs. I was planning a monolithic stair, having its structure made with concrete and have certain material finishes to it, such as dry bit on the underside and maybe some stone for its treads, yet I am having trouble finding a way to apply different materials to it. any help with this would be appreciated. Thanks~!
Wed, Aug 21, 2013 at 4:14:33 AM | Revit Monolithic Stair with Material Finishes
yasminmohsen
I have the same problem .. Help Please
Wed, Aug 21, 2013 at 8:24:22 AM | Revit Monolithic Stair with Material Finishes
Johnzo142
Try using the 'paint' tool.
Tue, Apr 14, 2015 at 6:00:26 AM | Revit Monolithic Stair with Material Finishes
mystykal06
You can change the material of all the components of the stairs (Thread, Riser, Run). Just go to the project browser, find the stair group, under this group you'll find thread and riser types. duplicate and rename a type and then change it's material. make sure you change the stair monolithic type properties to match the riser or thread type you've created.
Hope it helps!
CAN'T MAKE MONOLITHIC STAIR
Fri, Feb 5, 2016 at 10:16:18 AM
13
Monolithic Stair with Stringer
Wed, Aug 5, 2009 at 10:43:24 AM
Curved monolithic stair problem
Thu, Mar 11, 2010 at 2:33:31 PM
Monolithic Stair Question
Thu, May 26, 2011 at 7:14:39 AM
Monolithic stair - large construction height error
Thu, Oct 13, 2011 at 12:10:33 PM
Page generation time: 1.6905
