Forums >> Revit Structure >> Technical Support >> Visible project base point
Wed, Aug 7, 2013 at 3:46:11 AM | Visible project base point
robinsimonstad
Hi!
i'm creating a new template i Revit 2014, but when I create new levels the project base point and survey point doesn't show. I've tried to reveal hidden elements and marked them under "Site" in visibility/graphic overrides, but they doesn't get visible. I only see them in the first level, but not in the other created levels.
What is wrong?
In advance, thanks!
Wed, Aug 7, 2013 at 4:12:48 AM | Visible project base point
ronmalit
5 Stars: 3 Votes
im not sure whats wrong. but did you assign any view template under identity data on your property pallete?
normally, i will go to VIEW>VIEW TEMPLATE
on the first level: create template from the current view and,
on the other level: apply template properties to the current view.
** dont be mad, i dont have much... i am homeless
Wed, Aug 7, 2013 at 4:21:25 AM | Visible project base point
4 Stars: 205 Votes
From your HELP: http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/2278-Collabor2278/2470-Shared_P2470/2484-Project_2484
Read the first paragraph....
Wed, Aug 7, 2013 at 4:32:58 AM | Visible project base point
robinsimonstad
I've selected none in the view template under identity data on the property pallete.
Is it any settings I have to change? I quite don't understand why PBP doesn't get visible in this template because they're visible in other templates or projects that I open. I'm kind of new in Revit so I may have done something wrong, but I've questioned other people in the office and they don't understand they either.
I tried your way now, but no visible PBP or survey point.
possible to delete project base point?
Mon, Apr 29, 2013 at 3:58:58 PM
Shared Project Base Point
Tue, Mar 16, 2010 at 9:45:58 AM
Project Base Point
Thu, Jul 2, 2009 at 6:24:59 AM
Level that reads both Project Base Point and Project Survey Point
Tue, Jun 9, 2015 at 9:39:37 AM
copy with base point in revit
Fri, May 11, 2012 at 7:03:41 AM
Page generation time: 0.6564
