13 Users Online (11 Members):
Forums >> Revit Systems >> Technical Support >> KeyNotes
5 Posts No Rating |
I'm trying to set up a keynote system that will allow me number the keynotes by sheet, and the input text for the keynote is different per sheet. Is there a way to do it?
Thanks
Always look in your HELP - This is covered there.
Simple change the keynotes to "by sheet"
5 Posts No Rating |
Is there a way to have multiple keynotes text file?
My company uses Coded Notes on the sheets and many times the information in the coded notes varies from sheet to sheet.
Only one keynote file per project.
You don't need seperate files, just more items. So if your keynote file is:
- This is note one
- This is a different note 1
- Three
- Four....
And on sheet 1 you place keynotes in this order of placement 3, 4, 2, 1 then your keynote schedule on that sheet would be:
- Three
- Four
- This is note one
and on sheet 2, you place keynotes in this order 4, 1, 3 then your keynote schedule on that sheet will be:
- Four
- This is note one
- Three
Do you understand?
5 Posts No Rating |
I'm not clear with my message, lets see if I can make it clear with an example.
sheet 1.
- ONE
- TWO
- THREE
- FOUR
sheet 2.
- ABC
- DEF
- GHI
- JKL
Is there a way to do that?
I don't believe we are communicating. Please spend some time with your HELP reading about keynotes.
You may also find some good video tutorials.
Keynotes |
Thu, Mar 15, 2018 at 3:15:03 PM
Keynotes |
Thu, Oct 6, 2005 at 5:13:33 PM
KEYNOTES: only one keynote txt file and legend? |
Wed, Jan 17, 2018 at 12:33:01 PM
some keynotes not printing |
Thu, Sep 15, 2016 at 4:43:39 PM
Keynotes - Ledgend management |
Mon, May 11, 2009 at 7:01:29 AM
