14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> FATAL ERROR WHILE IN SKETCH MODE
6 Posts No Rating |
Hi All.
When i am editing the shape of a filled region or editing the shape of an extrusion or floor and i click on finish sketch Revit will come up with a Fatal Error and ask to save a recovery file. Sometimes it saves a recovery and sometimes it does not. i will always loose all the work in the sketch. it doesnt happen all the time, it only seems to do it when i am editing more complex shapes or using alot of lines in the sketch. Does this happen to anyone else? is there a way around it. It happens to other people in my office and we are all working on revit 2013 but has happenend in previous versions also. Any help would be much appreciated> thanks
Did you installed the 3 Web Updates to 2013? Specs. of your machine please??? Ram??
6 Posts No Rating |
have installed the updates and it still does it.
the specs of my machine are as follow:
Windows 7 Professional
Processor: Intel(R) Core(TM) i7-2600 cpu @ 3.40GHz 3.40GHz
Installed Memory: 8.00 GB
64-bit Operation System
Graphics as follow:
Display adapter type NVIDIA GeForce GTX 550 Ti
Total avail. graphics memory 4095
Dedicated graphics memory 1024
i Dont think its the Machine Specs cause it doesnt seem to bad to me.
is there anything else anyone can think of? its getting fraustrating when it shuts off and you loose work that has to be done all over again.
Cheers guys
47 Posts No Rating |
I had the same problem a while back but installing the updates corrected it.
nicolas .... so tell us exactly what your Revit says under the build number in the "about Revit 13" ... dropdown next to the question mark.
6 Posts No Rating |
Right next to where it says Build it has: 20130531_2115(x64)Update Release 3.
Is that the info you were after?
Fatal error when in any type of sketch mode |
Wed, May 16, 2018 at 11:28:43 AM
Question about sketch Mode |
Thu, Jan 17, 2013 at 6:34:56 PM
fatal error |
Wed, Aug 30, 2006 at 1:15:22 PM
Fatal error on a shared job Revit 2015 |
Tue, Mar 15, 2016 at 1:06:32 AM
Fatal Error when adding casework tag |
Mon, Apr 6, 2009 at 12:38:40 PM
