Forums >> Revit Building >> Technical Support >> Revit Reporting Parameter
Mon, Aug 5, 2013 at 7:26:19 PM | Revit Reporting Parameter
mmurder
Is it possible to have a formula that reports a dimension value in a text string? I'm trying to have a scaleable counter report the dimension in inches within the tag. So a 5'-0" counter would read XX-YY-60. Obviously the 5'-0" would already be a parameter noted as "Width".
Ex:
Parameter: ID-Tag
Value: XX-YY-(Formula Result)
Formula: "XX-YY-" plus the (Width) in inches
*Currently using 2011 through 2013. Because clients hate change.
**oh man first post ever! ...I think.
Tue, Aug 6, 2013 at 7:13:34 AM | Revit Reporting Parameter
You can not have a formula in a Tag ....yet.
Tue, Aug 6, 2013 at 9:22:23 AM | Revit Reporting Parameter
mmurder
Consider it less in the tag, more as a paramater. The Tag only need report a value(and yes the value can be a result of a formula). The question is more along the lines of: can you convert feet to inches and can you add this value to a text string?
I know I can just take the value 5'-0" and divide by 1" to get the value 60 as a work around, but I still don't know if I can add this to a text string. to provide the aforementioned case XX-YY-60
Tue, Aug 6, 2013 at 9:30:40 AM | Revit Reporting Parameter
There are no text string manipulations in Revit.  You can have a value that is in inches.
Tue, Aug 6, 2013 at 10:47:43 PM | Revit Reporting Parameter
ronmalit
5 Stars: 3 Votes
as far as i understand your question, heres my suggestion
in your counter family you should have parameters:
W(feet) = value <---- assigned to the actual dimension
W(inches) = W(feet)/12 <---- this should be a shared parameter so you can tag
in your annotation tag family:
"XX-YY-" <--- should be a text ,
and next to it is the LABEL "W(inches)" <--- this should be a label and from the shared parameter
** dont be mad, i dont have much... i am homeless
Wed, Aug 7, 2013 at 11:17:04 AM | Revit Reporting Parameter
mmurder
Awesome, yea, I was wondering if that would be an ideal work around. I was also considering a long nested If/Then formula for select dimensions, although that may get too long
Thanks!
Reporting parameter from curtain wall door in Curtain Wall Schedule
Mon, Dec 19, 2022 at 5:44:58 AM
11
Parameter for reporting Revit version
Mon, Jul 6, 2020 at 12:19:19 PM
Copy/array an extrusion in the "depth" direction
Thu, Sep 9, 2010 at 10:37:01 AM
INSTANT PARAMETER SCHEDULEABLE
Wed, Jul 11, 2012 at 2:08:57 PM
Radial array in Families
Thu, May 23, 2013 at 2:20:13 AM
Page generation time: 5.7274
