Forums >> Revit Building >> Technical Support >> Rvt 2013 Handrails for 3-run stair
Mon, Aug 5, 2013 at 4:21:20 PM | Rvt 2013 Handrails for 3-run stair
msaady
For some reason, Rvt doesn't like it when my stairs have more than 2 runs to get to a level.  The handrails work fine if I have a 2-run stair, but if it's a 3-run stair the handrails do not behave properly.  I can't seem to get them to work.  Any help would be greatly appreciated.
Mon, Aug 5, 2013 at 4:31:51 PM | Rvt 2013 Handrails for 3-run stair
msaady
I think I need to clarify:  The handrail at the center of the stair works fine.  When I want to change the handrail at the wall side of the stair, Rvt does not like handrail lines being broken at each landing.  How can I get a handrail on the wall side (wall mounted, not baluster mounted) to be broken at each stair section termination top and bottom.  Thanks in advance.
Mon, Aug 5, 2013 at 10:39:24 PM | Rvt 2013 Handrails for 3-run stair
CDWdavid
5 Stars: 5 Votes
Hi Msaady,
Please see these two threads, hope they can give you some ideas.
http://www.revitcity.com/forums.php?action=viewthread&thread_id=28323
http://www.revitcity.com/forums.php?action=viewthread&thread_id=22344
The way I did in the second thread "22344" was to start the railing from the bottom up to one step lower than the upper landings for both flights, than created top and bottom rail extensions with one section of railing for middle landing.
The reason I did that was the riser in each flight are different, because I wanted to set the landing at a certain elevation.
Edited on: Mon, Aug 5, 2013 at 10:40:15 PM
Tue, Aug 6, 2013 at 12:03:28 PM | Rvt 2013 Handrails for 3-run stair
msaady
I think I got Revit fooled into representing what I wanted to see.  CDW, your suggestion would not work for me as I have a stair with a double switchback to get up to a second level (3 sets of rises with the third rise directly above the third rise) as opposed to a single switchback with a double rise on one run (your PDF example).  Revit does not like the third rise of the stair when using it as a host for railings.  The first two rises behave as expected when using them as a host for a wall mounted rail.  The third rise when picked as a host will default revit back to the original (first) rise of the stair and will drop the handrail back down to the first rise.
So here's my work-around:  I created the original 3-rise stair, noted the elevation of the second landing, deleted the top rise of the stair.  Then I created an additional stair starting from the second level and then going down to the second landing elevation.  This enables revit to use the third rise as a host for the wall mounted rail at the high elevation as an individual entity and not dependant on the first rise.  I hope this description was clear and I hope this might help other users with similar issues.
The only drawback that I can see to this method is that the handrails (hand and guard rail) at the center stringers do not join at the second landing level (the intersection of the two separate stairs).  For me this is not too big of an issue as I can add a couple of drafting lines to join the rails as I see fit in our documentation sheet views.
Thanks for your time.
Wed, Apr 5, 2017 at 1:59:55 PM | Rvt 2013 Handrails for 3-run stair
Xanadu79
I have encountered the same problem, but if the railing is edited and is split on the lowest tread nosing line, it will host the the third run perfectly.  For some reason it the railing needs to be spilt to retain the third run hosted.
Stair Handrails and View Range
Mon, Mar 9, 2009 at 2:37:22 PM
Revit 2013 Stairs/Handrails
Thu, Feb 14, 2013 at 7:27:18 PM
STAIR HANDRAILS
Mon, Dec 13, 2010 at 8:50:19 AM
Help - stairs with arch run
Fri, Aug 22, 2008 at 8:26:28 AM
REVIT 2015 Stair - Straight Run to Curve Run
Thu, Dec 4, 2014 at 11:06:59 PM
Page generation time: 0.2390
